VIBE/Steering wheel shake 65MPH...HELP!
Originally Posted by HFLDtA
I got a 02 TA A4 20K original miles. I bought this car 1 month ago and ever since, the steering wheel shakes at speeds 65 & greater. I replaced all 4 rotors, rear brakes, balanced tires, & alignment check. I dont know what else it could be!!! The tires that came with the car are Falken 245/50 ZR16. When I bought the car, the PSI was around 40. I immediately put them down to the right spec (before I drove out of the dealer). Im goin on a 1000 mile trip in 2 months and would like to have peace of mind. Thanks for all the help!
Could also be a tie-rod.
Maybe you have a seperated tire or a bent rim.Are the stock rims on there?If not make sure the little star clips on the brake rotors are off. The factory puts these clips on at the factory the keep the rotors from falling off on the assembly line. These clips can cause the wheel not to sit flush and cause vibration.
If you just recently got your tires balanced, you might have them verify the correct balance. I had to take mine back twice before they got the wobble out. There was no wobble at any speed directly before the new tires went on, so the process of elimination was simple...
BobP
BobP
could be the front wheel bearing, i had that problem on my 02 Z28 with 48000 miles, to check that jack up the front and spin the wheel by hand, if you here a noise that the bearing is bad. hope this helps.
I would have the tire balance re-checked. Preferably, I would go to a shop will a RoadForce balancer. With 20K on the car, the vehicle probly sat for a while and can cause flat spots in tires (even with 40psi). Defenatly check for bent rim as well. Its is also possable to have a bent axle flange for front wheel hub. My money is on tires though since it only happens at 65+MPH. my .02
Today I noticed my passenger seat vibrates back n forth.
it sounds to me like maybe bad tie rods or loose steering rack
