Front End Popping??
Front End Popping??
Ok....Lots of issues here. I purchased my car with the eibach sportline kit already on it, However the previous owner used sensatrack shocks/struts ( bad idea). This set up not only blew out the shocks but im also getting a pop from the front end when i turn and im going through more powersteering fluid than gas. There also is a vibration coming from the rearend!!!! This is nighmare.. Other than the shocks ...what do you guys think i should replace? Should i go back to stock to avoid future issues? Whats the most cost effective way to fix this?
Copy & Paste Moderator
Here is a sticky on front end noises.
https://ls1tech.com/forums/suspension-brakes/696182-general-suspension-issues-questions-faq.html
