1-2 person job for RCBs and LCAs??
well ive never tryed suspension besides my srpings and im going to give it a shot tomorrow morning maybe for first time, how long should it take and is there a walkthough link someone can give me?
i figured i could do it by myself with not much problem, dont forget im putting the Relocation brackets on also... any idea on how long it will take and any walkthroughs anywhere so i can get a general idea?
heh, I was sitting there thinking "RCB...Remote Control Bearing? Radial Counter Balance?"
I did my relocation brackets myself too. Mine were BMR (gone now that I have a 12-bolt), so I followed these instructions:
http://www.bmrfabrication.com/INSTALL/CAB001.pdf
It probably took me about an hour or so to install the relocation brackets. Lower control arms were maybe 45 minutes.
-Mike
-Mike
I did mine with a buddy, considering I had 0 experience with suspension and he had done a 4" lift by himself on his truck in his driveway. You can easily do it yourself though. GO to www.InstallUniversity.com I used their site for some good advice. Good luck!
Originally Posted by 1meantransam
do you have to have relocation brackets on to put the new LCAs on? im kind of limited on time for both jobs this morning
am i off basis??
Copy & Paste Moderator
can anyone show me a GOOOD site showing how to for moving the brake lines with new brackets, or tell me what you did with yours?
I used a dremel to cut off the bracket where it wraps around on the inside (the L shaped portion closest to the differential), then painted the exposed metal. The emergency brake seems to work fine.
The only other thing you could do is to drill a hole close to the edge of the brackets where you cut them off, then drill and tap a hole in the metal plate behind it (on the rearend assembly) so you can bolt it to that mounting area to keep it from sliding around.
