12 bolt handling
12 bolt handling
i didn't know what thread to put this in, so i picked this one...
but anyways, my question is simple: i am going from a stock rear (2002 M6 Camaro) to a 4:10 moser 12 bolt with a detroit tru-trac diff. i understand the tru-trac is a better diff for handling bias, but will the extra weight of the rear offset this? will the difference be noticeable for a street driven car?
i remember a member (i think it was viper) who said he lost time around the track going to a 12 bolt, but how noticeable is that on the street?
thanks and i apologize for the annoying hypothetical questions.
Jacob
Jacob
Its a light more unsprung weight. Will it make the car a dog? Depends. Jsut be sure you got good shocks. But sometimes the 12 bolt is a good thing better posi and can hold the power. Even if it does add some weight.
I've heard the trutrac isn't much improvement over the T2 other than being a hell of a lot stronger. It can take a beating on the strip.
Picking a good handling differential is quite a challenge with whats available to us. I'd go with a T2R hands down if they made it for a 12 bolt or 9 inch. The 9 inch has a trutrac with preload that I've heard a tiny bit about but there isn't much info on it, but I think it's closer to the T2R. Also the Auburn Racer's diff is one that Sam recommends but I don't think that's available for the 12 either.
I have a 2000 M6 Camaro with a Moser 12-bolt, 4.10 gears, and a Detroit TrueTrac diff, so I might have some insight here.
Yes, the difference in unpsrung weight is very noticeable. When I first got mine, I was very unhappy with the ride. After I adjusted the shocks (Koni SA's), it was much better, but the biggest move in the right direction was getting lighter wheels. I went from 17x11 ZR1's with 315/35/17's to 17x9.5 Fikse FM/5's with 275/40/17's. I still have a couple adjustments to make (LCA relocation brackets), but the ride is much better now.
Maybe this thread will help:
https://ls1tech.com/forums/suspension-brakes/697206-unsprung-weight.html
-Mike
-Mike
https://ls1tech.com/forums/showthread.php?t=697206
-Mike
-Mike
Originally Posted by qwikz28
thanks mike! thats an awesome thread. the wheels i have are pretty light so that does make up for it. i will also be installing the relo brackets for the LCAs. i think i'm on the right track, i just need to adjust the shocks accordingly i guess. i have the Konis as well. so the 12 bolt isn't extremely detrimental to my handling is it? cause thats a great relief.
-Mike
If you have Koni's, you should be able to adjust it to your comfort. I certainly was. My car still handles great, and now that I've tweaked it a little more (and grown accustomed to what the rearend has changed), it's VERY close to where I want it. The stuff I'm not totally satisfied with can likely be fixed.
-Mike
-Mike
mike- you don't happen to remember you're settings do you? i think it would save me a bit of time to start from your settings.
Back - Pretty sure it's at a full turn from full soft.
-Mike
LS1TECH Sponsor
A 12-bolt is not in any way a good handling move. The unsprung weight is a lot higher than a 10-bolt is (and there aren't as many diffs to choose from). I'd sooner say a 9" if you have to change, but I'd say with a 10-bolt if you aren't in imminent danger of fragging it from 600 HP.
Unsprung weight is helped by compression damping, something SA's don't have the ability to change. While a little tweaking helped Mike, it's likely that would have helped with the 10-bolt as well. He somewhat countered the 12-bolt mass by moving down to smaller and lighter wheels (who's idea was that again???). But then consider if those wheels were on the car *with* the lighter axle too, even more help!
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Point of clarification, Sam. I was completely satisfied with my handling before upgrading the rearend. With the added mass of the 12-bolt, I became unhappy with it, so all the adjustments I made (including lighter wheels, which you are definitely credited with suggesting...plus they look badass ) were to get me back to completely satisfied. Which I am.
-Mike
-Mike
LS1TECH Sponsor
I just like to point out details. After all I'm the one always telling folks the details matter. I'm just glad the car got back to working appropriately.
__________________
