Bled 3 of 4 Corners- Good Enough?
I removed my front calipers to paint them and I stripped my front passenger bleeder screw while trying to loosen it... I have bled all corners but the front passenger, is this good enough? Or do I need to get a new bleeder screw and start over?
Thanks,
Lane
Thanks,
Lane
You're going to have to fix the front caliper and fully bleed the line. If any air is trapped in the line that caliper will not be able to build enough pressure to actuate the brake at that wheel.
OWN3D BY MY PROF!
Originally Posted by TooSlow02
A good pair of vise-grips and some patience should be all you need.
If your sitation was similar to mine, and you couldn't get the screw off with vice grips and turned your screw into a metal mess, you have another option. Replacing the whole caliper with a refurbished stock caliper from autozone is only 40 a piece for the fronts. They charge you a 40 dollar core charge as well until you give them your old caliper. I spent more money on tools to remove the bleeder screw than I did buying new calipers.
Both front bleeder screws wouldnt even come off with a 6 point socket when they weren't stripped. They were completely seized.
I autox and the remanufactured calipers have worked better than my stock ones. Probably since the pistons have clean and fresh seals and also that I put on ss brakelines and did a fluid change. Just letting you know those replacement calipers are an affordable option
