Help! Loud squealing from every corner after pad & rotor swap!
my brakes are squealing terribly! I'm not sure what to do, I put on brand new zinc coated rotors, brand new Napa safety stop pads, and all new metal clips that go at the ends of the brake pads and in the top of the caliper. I didn't use the shims that came with the back pads, but I did spray the backs of all of the pads with that sticky squeal stopper. I have no clue what to do, it's incredibly loud and annoying everytime I stop. Please help
-Chris
-Chris
I'm running Napa Brake pads and rotors and mine squeak and squeal to. People are always telling me i need new brakes but this brakes are basically new. They replaced them once because of this but they started doin it again not long after. Napa mechanics installed mine so i dont think installation is to blame especially on to sets of pads.I'm sure they would replace them again for free but i dont see a point in it cause the new ones will squeak and squeak. Oh yea they told me this was normal for them to squeak cause there high performance pads.
Yeah, that sucks. They are ceramic pads and I'm told they are the best brakes napa sells. I guess I'll just get some OEM or Hawk brake pads. I just took my calipers off and cleaned and then lubed up the caliper pins, & then sprayed even more of that sticky stuff on the backs of the pads and then hosed down the rotors and the caliper and then insides of the pads with brake cleaner. I took the car for a drive and they are still all squealing.
-Chris
-Chris
These cars seem real picky about pads. I'd install the shims because that's their whole purpose is to reduce noise. If it's still noisy and you can't tolerate it then go with a different pad. I found a can of brake squeal stopper in the spare tire compartment when I bought my car.
first off, you need to make sure u didnt just SPRAY the back of the pads, but put some of that grease or adhesive that keeps the pads stuck. the other would be a proper break in procedure.
Other than that, I wouldnt know.
-Chris
-Chris
