Question about doing my own brakes? - LS1TECH
Thread Tools Search this Thread
Old 06-11-2007, 02:54 PM   #1
Default Question about doing my own brakes?
OK i hear rubbing coming from my rear, and my brakes squeel when coming to a stop. I was wondering if i could just swap out the pads, and then fix the problem. The only thing i see in the rotor is a small single line tht goes slightly IN the rotor, all the way around. other then that the rotor looks flat, so do you think id be ok on just leaving the rotor if it only has the one line in it.
hasenbonkers is offline   Reply With Quote
Old 06-11-2007, 05:09 PM   #2
Nah,,,,, get the rotors replaced each time you do brakes. ... they are cheap...
robertbartsch is offline   Reply With Quote
Old 06-11-2007, 05:54 PM   #3
Greggy's Avatar
Rotors are like $40 to hundreds depending on what you get. I find no reason, at least in the rear, to replace the rotors unless they are warped, damaged or below min. thickness.
Greggy is offline   Reply With Quote
Old 06-13-2007, 03:06 PM   #4
Most stock rotors are warped. Buy cheap Ebay ones or, if you plan on keeping the car for awhile, then get the Brembo blanks...
99Andrew is offline   Reply With Quote
Old 06-13-2007, 03:41 PM   #5
z28bryan's Avatar
Quote:
Have you ever looked at a set of ls1 brake pads? They all have one side where a piece of metal sticks out off the edge, but doesn't protrude further than the pad material until the pad is almost completely worn. Your pad material has gone lower than the metal wear indicator piece which is causing the line digging into the rotor. It's time you replaced your rotors and pads
Brembo blank rotors are a great deal for the quality of rotor you are getting. You can get a set of cheaper drilled slotted wierd non-namebrand rotors as well, but you won't ever see those on my car. Check out the brake faq in this section and decide what you think is right for you. If I were daily driving, I'd probably just get some sort of cheaper duralast brakepad set for money reasons. For a good performance street set of pads, HPS you can't go wrong with.
z28bryan is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
CTSV Brake swap for track/daily use vs stock brakes nascardude56 Suspension & Brakes 10 10-16-2015 12:47 PM
CTS-V Brake Upgrade worth it? nascardude56 Road Racing 9 10-16-2015 11:06 AM
Anything special to remove rear rotors? Jorgens Suspension & Brakes 17 06-06-2015 07:23 PM
Brembo Camaro 1LE front calipers/pads/rotors g6t6o Parts Classifieds 3 03-21-2015 11:33 AM
New Brakes are not working! ws6formula98 Suspension & Brakes 9 03-13-2006 10:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
