What did I break (picture) and what do I upgrade it with?
Old 06-12-2007, 01:03 PM
Waveridr85's Avatar
Default What did I break (picture) and what do I upgrade it with?
I was putting in my Koni fronts and broke this. Should I replace it or upgrade it, the bushing seemed to have worn out pretty bad. It was at the end of the sway bar.
Thanks a ton for your help in advance
Old 06-12-2007, 01:10 PM
greenherb's Avatar
sway bar end link.... you can get away with ES poly endlinks autozone stocks them
Old 06-12-2007, 07:16 PM
chevy94c's Avatar
What he said
Old 06-12-2007, 07:20 PM
suburbanlife866's Avatar
The BMR sway bar end links are the same ones you can buy at Murrays....they will do just fine
Old 06-13-2007, 07:36 PM
vMaster0fPuppets's Avatar
i broke mine doing my front shock install. there swaybar endlinks. 2x autozone
like $12 a pair
Old 06-14-2007, 06:26 AM
ws6pewter's Avatar
Not to highjack but I I had to remove the end link on one side of my rear sway bar and I'm not sure how much I should tighten it down when I re-install. Anyone have torque specs?? I've already put it on and tightened it down pretty good, just not sure if it something that can be over tightened.
Thanks
Old 06-14-2007, 07:57 AM
DuronClocker's Avatar
Just tight enough that you can't spin the bushings with your fingers.
Old 06-14-2007, 09:50 AM
rd_ls1_z's Avatar
I think the torque spec is about 17ft/lbs.
Anything can be over-tightened, that's why there's those torque specs
Old 06-14-2007, 09:59 AM
ws6pewter's Avatar
Well if this is the case then I sure as hell over tightened it. Guess I'll loosen it up a bit when I get a chance.
Thanks
Old 06-14-2007, 10:36 AM
rd_ls1_z's Avatar
If you don't have a torque wrench, do as Duron said, or you can watch the bushings and stop tightening when there's a slight buldge in the bushings.
Old 06-14-2007, 11:02 AM
Bryan @ Speed Inc.'s Avatar
speed inc stocks endlink kits w/ poly bushings... www.ls1speed.com
Old 06-14-2007, 11:07 AM
5301113's Avatar
YUP
Quick Reply: What did I break (picture) and what do I upgrade it with?
