lca relocation brackets on a 9 inch
Are there any bolt on brackets that will fit a moser 9 in. I have bmr's and they don't fit. I would rather not weld them on since it came powdercoated from moser and I don't want to grind it down
Thanks
Thanks
Hello,
The problem with Moser rear ends is they make there control arm brackets much wider then factory and at the same time use thicker plate. They also do not mount there shock mounts in the "exact" location as a factory rear. So with that being said I really doubt you will find any compnay that makes a bolt on bracket for a Moser. We do offer a weld in version and it can be seen below.
www.umiperformance.com/2011
Hope that helps!
Ryan
Hope that helps!
Ryan
Wasn't knocking it at all there Ryan. I could tell that the mounts were different sizes from the drivers to passenger sides being that you're relocation brackets were the same size/shape out of the box, whereas the fit was different from the panhard bar mounting side compared to the other. Not sure if all moser housings are like that, but in that case you'd have to make 2 different width brackets for each moser housing instead of identical brackets for both sizes.
I didn't think you were. This problem is very common with Moser. The shame of it is, people call us and act like our products don't fit right. We tell them to call Moser and complain.. not us... but they continue to blame us. Don't get me wrong, we use Moser rear ends and they are just fine, its just there tolerances on control arm, panhard bar and shock mounts that make it more difficult sometimes.
This is the reason we can not make a bolt on relocation bracket for the Moser rear end.
