Brake Fluid?
Old 06-21-2007, 07:38 PM
2001bluerata's Avatar
Default Brake Fluid?
OK, gettting ready to install line lock, what brand of brake fluid are you mixing w/ the orginal factory Dot 3?
Old 06-21-2007, 07:49 PM
GR33N GoblinM6's Avatar
no.. get some ATE Super Blue.. its a DOT 4.. much MUCH better than plain jane brake fluid..
Old 06-21-2007, 09:12 PM
...and that's ok to mix w/ what's in there?
I don't plan on filling up an entirely empty system.
Old 06-21-2007, 09:21 PM
SS101's Avatar
don't drain it all the way or you'll have to trailer your car and take it to a dealership to have them do a many hundred dollar brake fluid swap with that niffty little scanner that you can't bleed the ABS system w/o...but if you just bleed them the conventional way you should be fine (don't let the master cylinder run dry). it's worth your time because mixing good brake fluid with shitty old fluid could cause problems...not to mention it'll make your new fluid shitty in a heartbeat.
Old 06-21-2007, 09:28 PM
cookba's Avatar
take your time and bleed them the old fashion way. i went through close to half my bottle of ATE just to make sure all the old crap was out.
Old 06-21-2007, 10:54 PM
If I add new stuff, it's going to mix, that's inevitable!
I'm sure if I keep bleeding, I will eventually notice a difference in color. Is that what I should shoot for?
Where would I get the ATE super blue DOT4?
Old 06-22-2007, 12:53 AM
Copy & Paste Moderator
VIP1's Avatar
Yes. Also, since ATE Super Blue is actually blue, it will be obvious.
Sam Strano.
If you don't see it on his site, call him. I know he has it. I bought my bottles from him over the phone.
Old 06-22-2007, 11:03 AM
Yahelou's Avatar
about how many bottles is needed to do this??
Old 06-22-2007, 05:59 PM
I don't have the time to wait for it to be shipped, I might try calling around to some speed shops tomorrow to find it!
I was going to ask if I need to bleed all 4 brakes, but I answered my own Q by reading the Haynes manual.
Good Q Yahelou, About how many bottles will I need?
Old 06-22-2007, 08:17 PM
VIP1's Avatar
Sorry, I don't remember.
Old 07-08-2007, 02:07 PM
BlackHawk T/A's Avatar
1 bottle, but if you are shipping, buy 2 so you have one for next time. 1 blue and one yellow.
Old 07-08-2007, 06:13 PM
mitchntx's Avatar
Brake fluid has a shelf life. Anything a year or more old shouldn't be trusted, even in a sealed container.
If your car is just a street car and won't see any AX or road course duty, Valvoline makes a good street brake fluid. Available almost everywhere. Comes in a gold bottle.
Old 07-08-2007, 09:23 PM
wannafbody's Avatar
Get the valvoline synthetic at Advanced or pepBoys-it's rated for 500 degrees
Old 07-08-2007, 10:46 PM
DuronClocker's Avatar
Yeah, that Valvoline is what I've been using in my F-body's for the past few years. I'm happy with it so far. Haven't tracked at all with it yet though. I'll probably order some ATE before Road America.
Old 07-09-2007, 07:23 PM
So does it expire after one year in a car as well, even with very little use?
Old 07-09-2007, 11:43 PM
Most suggest you do a fluid flush once a year.
Old 07-10-2007, 07:07 PM
LILWS6's Avatar
i second that its what we recomend at tires plus
