315s and lowering
315s and lowering
I was thinking about lowering my car with some strano springs and also geting some shocks but i just put on some tt2 that are 17x11 with 315 in the back... so does that mean i cant lower the back of my car because i will rub... if you guys kno of anything else to do let me kno thanks.
Im pretty damn low and I have 315's...it fits but I have my fenders rolled and plenty of BFH, actually I need a little more. The only time I rub is when I have a passenger and Im taking twisties pretty quick, I will rub the wheel well a little but its not that bad.
Or you can simply roll the fender lips, install longer studs and run spacers. You won't have to mess with the bumpstops or the inner fenders at all that way.
I'm haveing the same problem, I have a 95 TA with 17x11 TT2's with 315's, Eibach pro kit, QA1 12 way adj (set on 12)able PHB, fender lips rolled, and a BFH to the inner well and it still rubs.
What next more BHF I guess, btw rides like a tank set on 12!!
i have strano springs, koni SA, and going to put ZR1s on soon, with 17x11 rears. i rolled the fenders and ground the bumpstop some. the rims have the grandsport offset though, so less then idea for a TA. whenever i get tires, ill be able to run the new rims and find out if all that worked out or not.
