Bump Steer kit?? Alignment specs??
I am about to have an alignment done on the car and I was wondering if Baer is the only company that makes a good bump steer kit to solve the tramiling problem.
Also, should I get the alignment tech to use the factory specs or is there a special set of specs that will make the car handle a little better??
02 Firehawk with factory suspension
Thanks
Thanks
Copy & Paste Moderator
Originally Posted by bluehawk2
alignment
https://ls1tech.com/forums/showpost....38&postcount=3
