Brake pad wear problem
Old 06-24-2007, 09:26 PM
mrhzk35404's Avatar
Default Brake pad wear problem
This is on my dd. My front driver side outside pad wears down very fast and also causes my rotor to warp because of the heat. All my other pads look good exept for that one. The car is front disc rear drum. What could this be?
Old 06-24-2007, 09:28 PM
Silas2k's Avatar
u have drum breaks on your trans am? or is this another car?
Old 06-24-2007, 09:36 PM
mrhzk35404's Avatar
I am talking about a 1994 oldsmobile
Old 06-24-2007, 10:10 PM
Jon5212's Avatar
you've got stuck caliper pins/bad caliper. Sounds like the caliper is getting hung up on the guide pins, or the piston itself is not releasing after you let off the brakes. Pull that side off and make sure your guide pins move freely, if not, get some new ones along with a new caliper.
Old 06-24-2007, 11:31 PM
mrhzk35404's Avatar
The guide pins are well lubed and move. possible bad caliper???
Old 06-25-2007, 06:55 AM
Jon5212's Avatar
I would place it on a bad caliper, I've ahd that problem before on my previous Tauri vehicles
