best adjustable PHB for dd/autocross use?
Originally Posted by subtlez28
Alot of RR guys use rod/rod adjustable PHBs (myself included).
UMI makes high quality stuff, supports the board, and are reasonably priced.
For autocross you will want rod ends on both ends. Below is the item I would recommend, if you have any questions please ask and I will be glad to help.
www.umiperformance.com/2023
Thank you!
Ryan
Thank you!
Ryan
Are the Rod-Ends on the above Bar sealed? I think that LG motors offers one that has dust protected Rod ends to extend the life of the metal-metal bearings...
LS1TECH Sponsor
The rod-ends are teflon-lined and the little seals do little to nothing to help the life--I just had to send a couple of new ends to a customer w/an LG bar last week.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Kleeborp the Moderator™
What are the pros/cons of an adjustable PHR with rod ends on both ends? i know this is considered a race version but why? The only negative Ive heard is more noise. Same question for the LCAs as well
2. More noise (subjective)
3. Harsher ride (subjective)
Most people can't tolerate the noise or the harsh ride rod-ended components provide. I couldn't take the extra noise while my car was daily driven, but now that it is only my weekend toy, I'm going back to rod-ended components.
I have the 169.99 as stated. I can't tell any more noise or harshness, people that feel this, must have bad shocks or something. Mine is better and no negatives.
I love it!
I love it!
I love it!
I love it!
Originally Posted by MeentSS02
It took a few thousand miles before mine started rattling...it certainly wasn't my shocks (Strano revalved Bilsteins up front, and 3rd gen Bilstein HDs in the back).
Now I've heard that the LCA's with double rod-ends create a LOT of noise compared to the factory LCA's, did you have those as well at the same time???
I went rod/poly for the LCA's, i couldn't notice an increase in road noise, but my road noise level is already kinda high due to the TQ. arm. I have the umi rod/rod phr, I switched from an adj. poly/poly BMR, well worth it.
Originally Posted by Carlos01SS
I've had my double rod-end APHR from LGMotorsports for about 4 years, put over 40K miles on them and I have not heard any more noise than the factory one, I guess I was lucky???
LS1TECH Sponsor
First off, all rod-ends are NOT created equal. Secondly the amount of noise you get from good rod-ends is somewhere between none and very little. Cheap ones rattle like mad and always much worse.
__________________
LS1TECH Sponsor
I don't tend to put half-assed parts on. I'd always use a double-rod ended PHB personally no matter what the use since they deflect the least.
__________________
