to all who had to cut your front shock in half
Im swapping my front shocks out and I just cut my front shock in half because of the rusty nut. I cant get the top mount off of the top half of the shock. is it supposed to slide off or is there a trick to it.
Restricted User
The nut is a bitch of course. But in my case, even after I got the nut off the shock cup wouldn't budge. Nothing we did could get it to move. I took it to STS and they ended up having to cut it off. I got a new one through carquest for $48.
You may have to do the same.
I had to blast the nut off with a big impact gun but it messed up the threads. I then let the upper shock mount and the inset rubber piece soak in PB Blaster for a few days. It eventually came free. It just sits in the upper shock mount.
You may want to slather that entire upper shock mount area in anti-seize or a quality water-proof thick grease to reduce future corrosion. It's a common problem.
You're not alone. I soaked one of mine in PB blaster for three days, still wouldn't budge. So I used an angle grinder and cut an X in the nut, used a hammer and chisel to beat that off. Shock still wouldn't come out. I got heated and pulled out the sledge and absolutely destroyed the damn thing. It still hasn't come apart..I want to make a lamp out of it but I'm afraid it's going to budge on it's own and blow a whole in my roof the first day I have it in the house. lol...
