bmr torque arm and moser 9" help
Which holes are you guys using on the bracket fo rthe rearend. Closer to the drivers side or pass. I I use the ones closer to the drivers side I think I have to grind the **** out of the torque arm, but the other ones I will have to dimple the floor
Thanks for the help
Thanks for the help
LS1Tech Premium Sponsor
You might need to grind on the cast Moser bracket to be able to use the correct holes. This is due to a slight variation in the castings.
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Lee Spicher
(813)986-9302
