Torque arm and TSP TDs?
which torque arm will clear TSP true duals? i tried a searching but nothing would ever come up.. another question.. say i get a torque arm and im still on the 10 bolt, if that ends up breaking, and i switch to lets say a 12 bolt, i shouldnt have any problems bolting it back up correct? i was hoping one of the UMI T/A would be the one
hopefully UMI performance will chime in with part numbers but i already contacted them about it. i believe any trans mounted TA will clear fine and if your looking for a chassis mount then you have to get a trans mount with a relocation kit/ it a litle more money but itll get you what your looking for.
Hello,
Our item # 2205 that is shown in the link below was actually designed around the the TSP true dual system. It will clear fine and will actually add addtional clearance to allow you to tuck the system up a little bit higher. Please take a look at the installation picture below as well as the installation pictures in the link. Also this item will bolt up to the 10-Bolt, 12-Bolt and 9" rear ends.
www.umiperformance.com/2205
Originally Posted by 98mysticZ
hey which frame mounted torque arm non tranny mount was done for the duals? and did it have a dsl?
Hope that helps,
Ryan
