Pro-Kit springs and Ground Control coilovers?
Old 07-24-2007, 10:48 AM
kaos_'s Avatar
Default Pro-Kit springs and Ground Control coilovers?
If I'm using prokit springs with stock replacement shocks will I benefit anything from the ground control coilover kit? will that make my ride any smoother other than just being able to adjust ride height?
Old 07-24-2007, 11:20 AM
kaos_'s Avatar
i know some of you guys are all over those ground controls.
Old 07-24-2007, 11:28 AM
rocket22's Avatar
It depends on the shock you choose, and the spring rates you pick. You are going to a one rate spring compared to a variable rate like the pro kit spring. But change is really going to be the shocks, Your biggest problem is the shocks you have I have done some research and the best shock for lowering springs seem's to be Koni's.
But to answer your question, you most likely won't see a big improvement in just changing springs.
