Whats the difference between Single and Double Adjustable Panhard Bar
Old 08-02-2007, 02:18 PM
WS6Guy25's Avatar
Default Whats the difference between Single and Double Adjustable Panhard Bar
Just as the title state whats the difference? I purchased a double adjustable panhard bar for my car.
Old 08-02-2007, 02:42 PM
Kleeborp the Moderator™
MeentSS02's Avatar
A single adjustable bar is usually a bar with a polyurethane bushing on one end, and a heim joint on the other end. Thus only one side of it is actually adjustable.
A double adjustable bar has heim joints on both ends, so both ends are adjustable.
Old 08-02-2007, 03:32 PM
koolaid_kid's Avatar
Well, not exactly. The double adjustable can be changed while still mounted on the car. The single adjustable must be dismounted on one end to adjust.
The types of ends (poly, rubber, rod) are up to the individual manufacturer.
Old 08-02-2007, 08:46 PM
WS6Guy25's Avatar
Mines a rod is this going to affect my the suspension or do I need to get some bushings
Old 08-02-2007, 10:31 PM
02TransAm/Batmobile's Avatar
UMI has an "On-Car" single adjustable panhard bar. That's what I got.
Old 08-06-2007, 05:16 PM
01Z28M6's Avatar
To add just a little to the on-car adjust definition; you have a left hand and right hand threaded end adjustment with jam nuts. To adjust, you have both jam nuts loose and you simply rotate the rod to move the chassis from side to side. Then snug the jam nuts when you're where you want to be. It doesn't get any easier than this.
Quick Reply: Whats the difference between Single and Double Adjustable Panhard Bar
