Car Wont Hook With 150 Shoot
Restricted User
are you spraying out of the hole? if you are get a window switch and reprogram your setup. A Torque arm w/ tunnel mount relocation bracket will help also. If you're twisting off the line, look into a "drag" rear sway bar.
I'm having the same problem. I had to raise my on RPM setting on my window switch to 3600 to get mine to hook. I am going to order a UMI adjustable torque arm and hopefully that will help me be able to start spraying the car at 3,000.
