Torque arm question
Torque arm question
Im looking at buying a new TA (UMI) dont know weather to buy stock length or tunnel mount. Whats the diffrence? Also do i need an adjustable one?thanks guys...
I just noticed you have dual exhaust, the exhaust system is most likely in the way to run any type of tunnel mounted or short style torque arm. The item I would recommend is item # 2205- www.umiperformance.com/2205 this item is very street friendly but at the same time works excellent at the track. It also should allow you plenty of room for the dual exhaust and shouldn't interfer. Take a look at the link, in the installation pictures there are pictures of this item isntalled with a true dual system. Does this look like your set-up?
Thanks!
Ryan
Thanks!
Ryan
