what brake lines with c5 brake upgrade?
Hi.
I'm upgrading my front brakes to C5 brake using LG motorsports brackets. I'm doing stainless lines but which do I order: 97-04 C5 brake lines or 98-02 camaro lines. I've just heard that the C5 lines are longer which would be better since the caliper will be farther out and in test fitting, the stock f-bod lines look like they're a little stretched at full turning lock. Thanks for the help!
Originally Posted by HossinatorSS
...in test fitting, the stock f-bod lines look like they're a little stretched at full turning lock.
C5 Lines
I used the UMI brackets and the stock lines are just fine. However, I'm going to put stainless lines on later and will go with the slightly longer C5 ones. Should have done it at the same time. Recommend the C5 lines for you and do it all at once.
