I thought Koni SAs were externally adjustable? Pic
Waiting for all my parts to come in so I can start throwing them on, and the shocks were the first to arrive. I ordered the 4/3 combo but am not sure if I might have gotten th wrong front shocks. I was under the impression there was an external dial you adjust. I don't see one.
Are these the third gen ones?
Originally Posted by InsaneAuto86
The adjustment is at the very top before the threads. If I had a pic I would show you.
I rotate it in one direction and I can feel clicks, like over 15 of them and it was still going. I rotate it the other way and it clicks once then just smoothly rotates like it's doing nothing.
are you sure youre doing it right. you dont rotate the ring that says + -. you need an allen wrench that you insert into a window cut into the shock. youll see a silver ring with a hole in it. THATS the adjustment. make sure youre using an allen wrench or similar to adjust it.
Also, there should be NO "clicks". There are only point to point (within that slot/window) "sweeps" of the allen wrench/nail/whatever you use. the best way to adjust is to sweep it all the way to - , then count the full sweeps towards the +. This is what people are talking about when they give a rebound "number" for adjustment.
-Mike
