QA1's with stock springs ??
I am wanting to run the QA1 R series with the BMR cup setup so i can use the shocks with my stock springs, is it still going to be better than stock **** for the track or is it not going to workout well together, let me know guys
Yes the adjustable shock will work better than the stock springs/shocks.
You can set the front shock to #1 or 2 setting and it will give you a lot more weight transfer as well as speed up the weight transfer.
Plus with the front adjustable shock it has a coilover spring seat so you can raise or lower the front anytime you want without cutting or heating, changing the spring rate.
