frame connectors
frame connectors
i am looking at a set of bolt on sub frame connectors for a 02 ws6 . the set im looking at is slp bolt on subframe connectors does any1 here have these do they cause any ground clearance issues cause i plan on lowering the car soon w/ a set of 1-1/2" drop sport springs the car is a m6 w/ pacesetter headers and ory so are there any other clearance issues w/ my current set up???
Hello,
Our bolt on subframe connectors will cause you no ground clearance issues and will clear just fine with your Pacesetter headers. Take a look at the links below and if you have any questions please ask and I will be glad to help.
www.umiperformance.com/2002
www.umiperformance.com/2004
Thank you!
Ryan
Thank you!
Ryan
i like the 3 point connectors but i have a BMR driveshaft safety loop will this still work w/ the connectors or will i have to scrap it and w/ the torque arm set up in the pics do u also have the same crossover bracket w/ a loop and t/a bracket built in to it in case mine wont work
