Unfound rear suspension problem
Old 10-18-2007, 05:41 PM
kodiak's Avatar
Default Unfound rear suspension problem
99 ss all stock except for;
Adj. lca, Adj. panhard,and relo brackets!
this was an attempt to rid the car of wheel hop!
2-3 weeks ago I purchased some Adj. konis for the rear because of the noise coming from the left rear! I determined that the bilstein hd was bad! Every bump sounded like it was hitting the bump stop or something only on the left side! Put the new konis on as instructed by a lady at Strano full soft problem solved! The same noise has come back within 9 days! I have been under the car several times and do not see any other problems! Any advice would be helpful! Thanks
Old 10-18-2007, 06:01 PM
ls1ws9ta's Avatar
mayb your spring went out of place? mine did that once...ummmm are the nuts tight? the ones inside the car for the shocks?
Old 10-18-2007, 06:51 PM
JD_AMG's Avatar
What kind of adj. panhard bar and LCAs do you have? Are they rod-end?
Old 10-18-2007, 09:43 PM
kodiak's Avatar
Sorry it took me awhile to reply!
Yes I re-checked the the shock bolts!
All UMI single adj. !
This problem had occured before UMI install!
I will check springs !
thanks
