Strano Handling Packages?
Old 10-18-2007, 09:52 PM
BLK02TA's Avatar
Default Strano Handling Packages?
I'm kinda torn between the Stage 2 and 3. The main diff is the blistens vs. konis.
The car is a DD with mild track day usage. The main thing is ground clearance. I've heard that konis actually drop the car a little more, any truth to this?
Also does sam have a military discount?
Old 10-18-2007, 09:56 PM
ls1ws9ta's Avatar
stage 3 as the bilsteins that come in stage 2 are in backorder since march.
Old 10-18-2007, 10:02 PM
BLK02TA's Avatar
That sucks, any alternatives to the rev blistens?
Old 10-18-2007, 10:23 PM
coolformula's Avatar
Smile
yea the konis are a great replacment for the revalves
Honestly if you got the cash the konis are worth I have tried both!
Old 10-18-2007, 11:11 PM
Bow94z's Avatar
Get the Koni's...I kinda waited around for the bilsteins myself, but with no exact time frame on when they will be available i went with the Koni 4/3, and boy i couldnt be any happier...The koni's will lower the car more when they are set on the lower perch ( you have to see them to know what im talking bout)..but setting themon the lower perch is not recommended while using lowering springs....
get the Koni's and dont look back
Old 10-18-2007, 11:38 PM
JD_AMG's Avatar
Shocks do not effect ride height, only springs. The font Koni's have a spring perch that you can lower if you want, making the front sit 3/4" lower on stock springs.
Old 10-18-2007, 11:54 PM
BLK02TA's Avatar
Awsome I did not know this about the konis. Looks like I'll be set for Road America in april.
Old 10-19-2007, 12:38 AM
30thanniv's Avatar
Does anyone have part numbers for the Koni's and a sponsor to buy them from. I want to lower my car but not too much. If I could lower the front by 3/4 inch with the konis and remove the rear isolators I would be happy.
Old 10-19-2007, 02:05 AM
BLK02TA's Avatar
Thats actually not a bad idea. How much does removing the isolator drop?
Old 10-19-2007, 07:35 AM
JD_AMG's Avatar
stranoparts.com
Old 10-19-2007, 07:41 AM
UMI Performance's Avatar
Originally Posted by JD_AMG
stranoparts.com
You can also PM Sam.. his user name is "Sam Strano"
Quick Reply: Strano Handling Packages?
