Koni - one or two adjustments?
Old 10-19-2007, 12:58 PM
robertbartsch's Avatar
Default Koni - one or two adjustments?
What are the various Koni shocks that are avialible for f-body cars. I see some have dual adjustments and others are a single adjusting shock.
What is the difference; what exactly do they adjust? Are adjustments made on or off the car?
Old 10-19-2007, 01:06 PM
LS1TECH Sponsor
Sam Strano's Avatar
There are single adjustables (two sets) and double adjustables. All Koni's adjust rebound. DA's adjust compression too, and seperately from the rebound. But you can't go down on compression only up.
All fronts are adjustable on the car. Some rears are, some aren't.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 10-19-2007, 05:47 PM
Out1aw's Avatar
Sam explained this perfectly, and from what I've seen... the DA's aren't really necessary on just a plain-jane street car. The SA's will suffice just fine. Now if you are doing constant track days and looking for every second off of your lap times that you can get through a fully adjustable suspension setup, or if you just have a few hundred bucks burning a hole through your pocket, then the DA set may be what you need.
