Lifting the rear end
Old 10-20-2007, 01:56 PM
Chilo's Avatar
Default Lifting the rear end
I have an audio system setup and the rear of my car is sagging. When ever I load up the car with people it will drop a couple of inches. What would be the best setup to level off the car? The car is a 2002 Camaro SS all stock. I would like a performance setup. I was thinking about coil overs but not sure if they work in that way(to lift a car). I tought they were to lower a car instead. Another thing I was told were to use drag bags in the springs. What do you all think. Thanks
Old 10-20-2007, 10:08 PM
Sunset'01Z's Avatar
drag bags would work the best i think. just dont overload the car, it's not built for hauling anything but ***.
Old 10-21-2007, 02:35 AM
Mike 01WS6's Avatar
Hahahahahaa
I second.
Old 10-21-2007, 05:42 PM
chrismorales75's Avatar
You could use a spring with a stiffer progressive rate
Old 10-22-2007, 06:01 PM
Chilo's Avatar
The only problem with spring in the market today is that they will usually drop the ride height from one inch or more. I am pretty sure with some trail and error I will find some springs for a different application that might level off the car but I don't want to go through the trouble. I really don't always load the car up with people. Do you all think the heater hose one the spring will work to level it off a bit? I also recall seeing on a search I did about spacers. I mean, that will level off the car for now but my concern was for those days I bring friends along for the ride.
Thanks for the replys.
Old 10-22-2007, 06:18 PM
JD_AMG's Avatar
1LE springs have higher rates and no drop over stock springs. FYI heater hose is for rear only if you didn't know, and generally drops the car around 3/4". Make sure to get some good shocks too, that will dramatically improve ride and handling and help from bottoming out.
