brake help please read
Old 10-21-2007, 02:25 PM
redramair98's Avatar
Default brake help please read
In my car the brakes work fine for like 2 miles, after that the pedal is stiff and wont move at all, and you can feel the brakes are on and smell them burning, and almost caused me to wreck, changed brake booster and still same problem, any help would be greatly apreciated
Old 10-21-2007, 05:24 PM
chrismorales75's Avatar
Piston in the caliper getting stuck??
Old 10-21-2007, 06:46 PM
Copy & Paste Moderator
VIP1's Avatar
Damaged calipers(pistons), lines, sliding pins?
Have you checked any of those?
Old 10-22-2007, 08:42 PM
no but it does seam to be coming from the right side where the brakes, heat up hopefuly the next day or two i can check into it more
Old 11-04-2007, 11:26 AM
pistons and lines seam ok, put antoehr brake booster in and still same problems, bleed all lines, even used diagnostic scanner and did automated bleed, AND STILL CANT GET THEM RIGHT
Old 11-05-2007, 03:04 PM
anyone?
Old 11-05-2007, 03:22 PM
z28bryan's Avatar
Did you check the caliper pins yet?
Old 11-05-2007, 06:54 PM
yep caliper pins were cleaned and greased
Old 11-08-2007, 05:24 AM
even was told to pull the abs fuses, so the abs pump would not come on and it still does it
Old 11-08-2007, 09:12 PM
01bad ss's Avatar
Is abs turning on? If it is when? Maybe try a new master cylinder?
Old 11-11-2007, 10:23 PM
FU_I_AM_UltraZ's Avatar
bad master cyclinder? mine is bad and i've only got 60K miles on the car and the rear brake pads seem to be untouched after 5k miles and for me... i normally have to change pads every 10k if not sooner.
Old 11-19-2007, 05:50 AM
well i tried a master cylinder and still same problem, i am goin to try front brake hoses since this seams to be about the only thing i have not changed
Old 11-22-2007, 07:38 AM
now put stainless brake lines still no help
Old 11-22-2007, 10:52 AM
blackbird4's Avatar
Did this just all of a sudden start happening or had you done any brake work prior to this? Have you checked to see if you have a rotor that may be warped. Should not be this hard to figure this out. Just hate you having to spend so much cash with no positive result. You say it seems to be from the right side . Is it possible the right side is doing all the work and the problem is actually coming from the left. Just a thought. Would like to have the car in front of me to try and help you out. Good luck
Old 11-22-2007, 08:48 PM
well its both front wheels locking up, i been thinking the abs unit but everyoen said thats wrong but this is the last thing to change and im do it this weekend, it sucks
Old 11-25-2007, 08:28 PM
officially ready to kill myself, put abs unit in bleed brakes again and it still locke dup roters turned red hot
Old 11-25-2007, 08:35 PM
only thing left is calipers but wats the chances of both them goin bad at same time?
Old 01-06-2008, 12:11 PM
bump someone got to knwo the answer to this
Old 01-06-2008, 07:32 PM
mjcotroneo's Avatar
maybe proportioning valve. or check if there is a kink in any of the brake lines. and not just to the caliper.
Old 01-06-2008, 07:39 PM
haperry678's Avatar
2000 Pontiac Grand Am
Engine: 3.4 L / 207 CID / 6 cyl / Gas / OHV
Fuel: Fuel Injection
Ignition: Distributorless
Trans: 4-speed Automatic Transaxle (Electronic)
Mileage: 88,097 mi
VIN: IG2NF12E6Y
Misc Data: sedan
Affected Item: Brakes lock down
Condition: overheat@ 10-15mi
More Info: Test results & repair history included below
_____________________ ORIGINAL MESSAGE _____________________
Hi gang,got a customer here w/pontiac G/Am='00 w/abs= when
it's driven over 10 miles,brakes begin to lock-down,today he
drove a little further;church,etc. + brks.locked solid,had to
tow it,the brk's had cooled enough to drive a short distance
into bay. I loosened m/cyl from booster;did-not help;wheels
still wouldn't turn,finally loosened L/F bleeder+ all wheels
began to turn,Though it was a brk. hose because l/f cal.
piston would not retract untill i opened the bleeder
valve;;;replaced hoses/pads+ bled + o.k. for 12 miles+ noticed
no more brk.pedal free-play,was able to get it back to bay But
real hot,not smoking though,like it had w/ him. Loosened Rear
m/cyl. line+wheels turned freely. WHAT'S going on,do i need a
m/cyl, please help, g.b.
___________________ TEST AND REPAIR DATA ___________________
TESTING AND RESULTS
brk.light swx. - properly adjusted cruise swx. - properly
adjusted booster pushrod - not touching/ ALSO non-adjustable
RELATED REPAIR HISTORY
Frt pads 5 wks ago=now overheated/crumbling of pads; inners.
__________________________ SUMMARY__________________________
Hi All, i got 8 replies + most said 'contaminated brake system
+master cylinder cup seals swelled/as well as possibly
calipers w/cyl's etc, i did replace the frt. hoses previous to
request + flushed system/adjusted stoplite swx. Customer said
the next day that It was acting O.K., therefore he has not
returned,If he does i will reinitiate Help request,or
close/w-fix. My opinion after the work was: it still has a
problem binding down/heating brks,but he seems satisfied for
the time being, thanx, g.b.
Hopfully this will help
