torque arm question
Old 10-26-2007, 09:40 PM
import slayer's Avatar
Default torque arm question
I just put in this torque arm ( Link below ) and the crossmember where the DS safety loop is my Y pipe is sitting right on it. When I drive it makes this horrible noise and I can feel it banging against it. Anyone have the same problem. Also I am not 100% sure but I think it is also hitting the DS safety loop itself.
http://www.exoticperformanceplus.com...html?item=1186
Old 10-26-2007, 10:29 PM
INMY01TA's Avatar
I had the same torque arm, fit my car fine (Strange 12 bolt). I sold it to a guy with a 9 inch and it did the same thing to him. It changes the angle of the shaft I believe. He cut/clearanced the ds loop alil. Not uncommon.
Old 10-27-2007, 10:39 AM
02Z28LS1's Avatar
you could always just go get some flat viton gasket material (sold in sheets of varying thickness) and cut a small piece that would fit in between the y-pipe and the bracket. viton is for high-heat applications, up to 392° F, and should get rid of any clanking between the exhaust and the bracket.
i used to work at a place that sold the stuff, it was an industrial supply company....we sold gasket materials, hydraulic hoses/fittings, etc. to farmers & oil companies.
just cut it to fit the size of the bracket, then either glue or zip-tie it onto it.
i'd suggest getting several different thicknesses to see what would work best...it comes in sheets anywhere between 1/16" - 1/2" thick, and maybe even thicker.
the only downside i can think of is that the stuff is somewhat expensive, but i wouldn't trust any other rubber-type material, as it would likely melt and/or catch fire.
Old 10-27-2007, 02:00 PM
427Cya's Avatar
I have just installed 2 of the exact same torque arms on a camaro and a transam both with 9" in them. WE are having the same problem. I took the torque arm back out (pain in the ***) and adjusted both of the bolts back by the rear end at least an inch each and it gave some clearance. Make sure to go to harbor freight and get a magnetic angle finder and set your torque arm to -2degrees or you will have crazy wheel hop at the track.
Old 10-27-2007, 10:25 PM
when You adjusted the bolts on the back. did it fix the problem? Also I am at -2 degrees already do I just need to adjsust those bolts?
Old 10-27-2007, 10:26 PM
You say he cut and clearenced the DS loop. Was it to long?
Old 10-28-2007, 01:31 PM
We fixed the exhaust touching the crossmember but there is still a nasty thudding/grinding noise when I drive 60mph or faster what the hell could that be?
Old 10-29-2007, 12:23 PM
anyone???
Old 10-30-2007, 11:34 PM
bump...
Old 10-30-2007, 11:37 PM
djsanchez2's Avatar
I had the same problem, i fixed it with the good ol' BFH mod.
Old 10-30-2007, 11:39 PM
Whats the BFH mod?????????
Old 10-30-2007, 11:40 PM
Copy & Paste Moderator
VIP1's Avatar
BFH = Big F###ing Hammer
Old 10-30-2007, 11:42 PM
funny ****
Quick Reply: torque arm question
