rear bagning noise
Old 10-28-2007, 10:08 AM
DevilDougWS6's Avatar
Default rear bagning noise
Over certain bumps it sounds like something in the rear is banging around. almost like hitting the bottom of the car. I did have a problem that the where the torque arm connects to the trans the bolts had walked out or broke and the the torque arm was just free hanging. well i fixed this, but now im not sure if the rear shocks are bad or what, but it almost seems like wheel hop becuase if i spin the tires a little bit out of a turn it does the same.....very confused. i have adjustable shocks in the back, not sure what they are they came with the car.
also the car was lowered with these shocks all around when i bought it, but i put the stock springs in because the front was WAY too low (the neg. camber in the front was rediculous) but i had to put stock front shocks in as well. anyone with info would be appreciated.
Quick Reply: rear bagning noise
