kmember question
Old 10-28-2007, 06:04 PM
Ruckus46Gt's Avatar
Default kmember question
I have to change my motor mounts and figured while i'm at it i'll swap to an aftermarket kmember. Question is what kmembers can i use my stock a arms with and do i have to run coilovers or can i use the spring/shock set up i have currently? Also umi, bmr, or pa racing. I'm leaning towards pa racing cause i've used there kmember before and had no issues but have been hearing good things about the other 2 also.
Thanks in advance
Old 10-28-2007, 06:15 PM
InsaneAuto86's Avatar
I just installed the UMI k-member and it is SWEET! I am pretty sure you can re-use all your stock hardward (a-arms, shocks) With any k-member.
Old 10-28-2007, 06:39 PM
ssgunny's Avatar
+1. You can double check at their sites but I think they all are able to use the stock A arms and shocks (I know UMI does for sure).
Old 10-28-2007, 06:51 PM
Ruckus46Gt's Avatar
good cause i really didnt feel like swapping out to coilovers and that right now. Just bought new shocks and spring not to long ago
Old 10-28-2007, 07:57 PM
02SSLE's Avatar
Sweet car man
Old 10-28-2007, 08:01 PM
UMI Performance's Avatar
Hello,
You can use all your factory items with our K-member and there is no need to purchase new A-Arms or a coil over kit.
If you have any questions regarding our K-member please ask. I insure you would not be disappointed in it and if you are running the vehicle on the street it is designed to handle street abuse.
If I can help anymore please ask. Thank you!
Ryan
Quick Reply: kmember question
