torque arm fitment
Old 10-29-2007, 09:33 AM
dutinsss's Avatar
Default torque arm fitment
will a UMI Tunnel Brace Mounted Torque Arm Long Tube Header Set fit my '02 camaro with a 10 bolt when i swap it with an aftermarket rear-end? also, will i need the BMR panhard rod relocation kit for 3'' true duals over the axles? thanks
Old 10-29-2007, 08:24 PM
UMI Performance's Avatar
Hello,
Our torque arm will fit all rear ends so you can install it on a 10-Bolt now and a 12-Bolt at a later date.
Also we offer a relocation bracket too and is recommend for addtional room for running 3" duals over the axle- www.umiperformance.com/2024
If you have any questions I can help with please ask. Thank you!
Ryan
