just got some goodies in!!!!
Came home from work and found Strano springs, Koni SA 4x4's, UMI adjustable lower control arms, UMI adjustable panhard bar, and lca relocation brackets....got tommorow planned out. question though....where do the washers go supplied with the Koni front struts?
LS1TECH Sponsor
The big washers go on the top stud of the shock, under the shock mount which sits on them, and they need to be there or you will eventually break the shock mounts.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
