anyone else have a prob. with koni?
just installed koni sa 4x4 and the right rear will not adjust. not with the flimsy **** provided, or with a pair of vice grips. it will not turn at all!!!! anyone else have this problem?
also....are strano springs supposed to be used with the factory rear spring isolators?
thanks for the reply...however i was not asking how to adjust them. theres a **** supplied with the rears that you place on the top and turn for adjustments. the right rear with not turn...so for those of you who have 4/4s, have any of yall had this problem and overcame it before dealing with tech support?
ok...i removed the shock from my car today so i could get a better grip on the adjuster...it finnaly came loose and it is adjusting fine now. thank yall for your help.
