Just installed the New susupension setup!!!
Done with Drag racing, in with handling!!!!
- Koni adjustables front and back (4/4 kit from Strano)
- Strano front and rear sway bars
- Ground Control Coil over kit (550 in front, 175 in back)
This thing handles like it's on rails!!!! Feels a bit shaky going over bad surfaces, so subframe connectors are next! (I seriously can't belive I still don't have subframe connectors)
Sorry no pics of before after right now but I'll post some later when I get the car cleaned up and the ride height adjusted after the springs settle, but here's pics from the install :grin:
LS1TECH Sponsor
Not knowing where the shocks are set, the tire pressues and a lot else....
The fact you have boxed/poly LCA's, and 175 rear springs is part of the issue IMHO. I know 150-175 doesn't sound like much difference, but it's 15%. And the LCA's you have don't let the axle articulate particularly over one-wheel impacts, which is what we want the supsenison to do.
Again, maybe you have the shocks full stiff. Maybe you have 35+ psi in the tires, I'm not sure.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
So the LCAs I have aren't that good for my setup? Tubular/stock LCA? Rod ends? rod/poly combo?
Might want to go up on the fronts one sweep firmer, and down on the rears 1/2 turn (1/2 turn from full soft). After the shocks break in that is what work best for me, although I have rubber 1LE bushed LCA's. The front get a bit harsh if the rebound is set too low and the rear will loose contact with the ground over bumps if its set to firm.
Ow and as Sam mentioned, definately make sure the cold (70 deg.) pressures are aoround 32 psi front and 29 rear. Any higher make the ride to firm and does not allow enough tire compliance which is needed for maximum grip.
LS1TECH Sponsor
Might want to play with the settings a bit on the shocks, particularly the rear.
As for the LCA's. Basically what you have is good for axle hop becaue the bushings don't want to deflect much, and the arms don't flex. That's great when you are going straight. But what we want is the lack of bushing and arm deflection, but with some ability to articulate. When the car rolls, or you hit a bump, the axle has to pivot. With arms like you have, they don't want to let it. Basically it's a bit of a binding situation. The solution I use: http://www.stranoparts.com/partdetai...D=10&ModelID=2
Bushing on the body end to insulate possible rod-end noise, but a rod-end on the back that allows the axle to move and articulate freely without bushing wind-up and flex.
__________________
I was going to go with the Strano sway bars, Strano springs, Koni 4/3, BMR tubular- non adjustable LCAs, and the BMR boxed weld-in SFC's. Input?
Also, are LCA relocation brackets a good idea? They are currently installed on the car.
Thanks
Andy
LS1TECH Sponsor
Are the spherical ends good for the street? I guess they dont make noise, like you said the body side (poly bushing) will insulate noise. If you suggest these over a non adjustable tubular LCA, I will go with that.
Thanks
Andy
Thanks
Andy
The only input I'd add, is you can do some one stop shopping if you would consider UMI products, which is what I use and carry. The setup you wanted, with the changes I'd make would be:
http://www.stranoparts.com/partdetai...D=18&ModelID=7
http://www.stranoparts.com/partdetai...D=22&ModelID=7 If you want 2-pt. boxed welded.
*or*
http://www.stranoparts.com/partdetai...D=22&ModelID=7 Which are 3-pt welded, but tubular for a tighter fit.
http://www.stranoparts.com/partdetai...D=18&ModelID=7 The bars.
http://www.stranoparts.com/partdetai...D=20&ModelID=7 The Koni 4/3's.
__________________
LS1TECH Sponsor
My springs are first and foremost about handling. They do look pretty good too, but they are not, and were never intended to be "looks" springs.
LCA brackets: have their place, for what I like from a car, I tend to not use them. Or, if they are there and/or the car is dragged a lot of has wheelhop issues, we'll use them, but move the adjustment for street vs. strip use.
__________________
Haha, definitely a handling upgrade. I did one thing at a time, and went from having the Koni SAs and Strano sway bars, then the springs. Huge difference, before the springs, with just the shocks and bars, the car was like a very well tuned street car, now its like a race car with street tires in the handling department...
I figure I want to do the springs and shocks at the same time since you need to take the strut assembly apart. Then I can always slap the sway bars on at a another time.
I want to do the SFCs and LCAs at the same time too, since you need to pull the LCA bolt for both to install.
Andy
Andy
LS1TECH Sponsor
Nothing wrong with that plan, I think it's smart when folks do things in steps and not all at once so they can see what happens and assess the changes. The shocks and springs are certainly the bigger change for ride and handling than the SFC's and LCA's.
__________________
The reason why I want to replace them is the SLP bolt in SFCs that are on the car are rusted pretty bad. I guess I could clean them up and weld them in to save some cash. There is a "clunk" in my rear suspension. I am taking a educated guess and blaming it on the LCAs (stock- loose?) and PHR (UMI ? w/ spherical rod end- plain old noisy?). I couldnt tighten the LCA bolts with the car on jackstands in my driveway. I might have a local shop tighten the whole rear suspension for me before I begin buying parts to slap on there. The LCA's are cheap enough and the UMI tubular adjustable ones are probably twice as good as the stockers. Another guess is maybe a rear shock is bad. Who knows.
So maybe for Christmas I can buy myself Koni shocks and Strano springs?!?! Hehe
Andy
Andy
thats a good idea and wish I would have done that, but I didnt know if I wanted to lower the car at first, so I just went with the Konis for starters. Either way those alone make a huge difference.
