EBC yellow stuff. any one using?
Old 11-13-2007, 11:25 AM
Turbo V6 Camaro's Avatar
Default EBC yellow stuff. any one using?
I have hawk HPS now, i get lots of dust, and they don't hold the car at the line very well, and don't seem to brake well when cold
the main reason i would get these pads is for the "cold" performance. I need more holding power so i can stall the car up more when staged without rolling.
any info would help, i searched but couldn't find any thread on the yellow pads
basically i need better grip when stage so i can stall my higher. even 300 RPM would help a great deal
Old 11-13-2007, 09:49 PM
slick1851's Avatar
Maybe upgrading to Z06 brakes? Or LS1 daul pistons?
And try and get more heat into the pads befor you stage or drive the car
give it a coupe hard brakes, or ride them a lil bit
Old 11-13-2007, 11:00 PM
daniel6718's Avatar
you talking about rear or front brakes?
Old 11-14-2007, 06:56 PM
both
I can't drive the car around to get them warm if I'm in the staging lane for an hour
Old 11-14-2007, 08:25 PM
SOM02WS6's Avatar
The front are dual pistons and unless your talking C6 Zo6 there wouldnt be much difference..
Old 11-15-2007, 07:09 PM
hpjunky98's Avatar
LT1s are 1 piston front and rear...
Old 11-15-2007, 09:04 PM
RE AND CHERYL's Avatar
The Yellows are a competition type pad and not good for street driving as they require heat in them to perform right. I'd get greens or Hawk HPS pads.
Unfortunately brake pads are a lot like cams. Many bite off more than they need in a hope for better performance and some times regret it later.
Re'
Old 11-15-2007, 10:51 PM
LSGunZ28's Avatar
I used the hawk HPS pads( those are the 80 dollar street/strip pads right?)
I used the EBC yellowstuff now, they seem to bite a bit better, I havent noticed slippage if they were cold..
but I see more dust than Hawk and more brake noise thank Hawks. Unless I just never noticed with the hawks..
Anyways, Im a 2002 z28 though..
Old 11-16-2007, 04:39 PM
cool
it says they have great cold performance and are rated hight the the hawks for cold performance
Old 11-18-2007, 07:35 PM
kicksZ28's Avatar
I use the Greenstuff pads with slotted rotors and it works great!
Old 11-19-2007, 01:39 AM
Shockwave179's Avatar
HPS should work fine in the cold, this doesn't make much sense. Yellow's probably won't be any better sense they are more a race pad than HPS even though they claim to have a decent cold bite.
Quick Reply: EBC yellow stuff. any one using?
