pass rear sits higher after lowring.. need advice please
just finished swapping the stockers for some pro-kits. got everything to finally go accordingly and tighhtened... but now as i take a step back and observe, my pass rear is sitting noticeably higher than the other 3 corners.. im sure i did everything accordingly.. so anyone have any advice on what i should double check??? right side looks bad *** btw.. ill post some pics asa figure out whats wrong with that one side.. thanks guys.. all input would be much appreciated
first drive it around the block and over some speedbumps to have everything settle it might just be the way it came down from the jackstands .
if that doesnt work you might want to check if you stacked both springrubbers on the same side
check the spring and shock and make sure the spring is sitting correctly on the rubber isolator...that's what i'll be doing tomorrow (i'll let you know if i find something unusual)...i'm getting an alignment and tire balancing this week and if it still looks that way then imma take it to a shop and see what the hell is going on!!
