Possible Break Upgrade?
Old 12-12-2007, 09:25 PM
01riceeater's Avatar
Default Possible Break Upgrade?
I was just wondering how much I should expect to pay for a nice set of used rotors and pads? thanks guys....and also how much of a bitch installation is going to be....
Old 12-12-2007, 09:46 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Brake upgrade using used parts? Or did that just come out wrong in your post?
Intall isn't hard, just messy. Brakes always are. Plus, it depends on the overall condition of your vehicle...if you keep up on its maintenance, it won't be as bad as if it is the first time you've ever taken the wheels off.
Old 12-13-2007, 05:55 AM
robertbartsch's Avatar
never use used parts for brakes. brake components such as rotors and pads are inexpensive anyway.
Old 12-13-2007, 08:26 AM
lol i just learned something today. i know autozone type breaks are realatively cheap , but im a bit more intrested in a brembo set up. one thing i am wondering is if i need to change the lines or not? thanks fellas
Old 12-13-2007, 08:28 AM
Also, could i just get pads for now and then rotors? Im leaning towards hawks pads....
Old 12-13-2007, 12:28 PM
jmilz28's Avatar
For Pete's sakes, you're looking at a "brake" upgrade - not a "break" upgrade.
What are your goals and budget? Are you having a problem now or do you just want more?
My guess is it's time for a brake job anyway and you want to upgrade at the same time. Let me recommend:
Hawk HPS pads
Brembo blanks (or local parts store rotors if on a budget)
Stainless lines
Complete brake flush with ATE blue fluid.
That will feel worlds better to you and have better performance.
You could always get LG brackets and C5 rotors for some additional leverage on the rotors but that will be an extra $350 or so beyond what the above will cost, about $400. Good luck!
Old 12-13-2007, 12:30 PM
hpjunky98's Avatar
I auto-x with duralast blank rotors, they wont make you stop any faster, but they will resist warping better than stock (yes, stock rotors do warp). As for pads, do some reaserch and find out what best suits your needs. I run hawk pads, but there are alot of other options out there. And jmilZ28 is right about the brake fluid. Make sure at the very least you bleed your brakes after the install. good luck
Old 12-13-2007, 12:54 PM
MeentSS02's Avatar
If you get the pads, make sure you turn the rotors. If the rotors have been turned once before, you probably won't be able to turn them again.
Old 12-25-2007, 09:13 AM
im leaning towards just the front, simply because of a lack of funds
