LCA relocation setting ?
On a couple different relocation brackets i've seen for sale, you can set it at 2 or 3 inches. What does this change? Oh and my car is stock ride height, dunno if that makes a difference.
It changes how the rear end behaves under different driving conditions. You want to have your LCAs as close to level as possible. I experimented with mine and when I had the back too low, the rear of the car tended to slide out while going around corners.
