Have Intrax Springs, what shocks to use?
I am running stock shocks with Intrax lowering springs. The car is 2" lowered, and that is about 1/2" too much for me; and she rides like a buggy! Anyone think I can get by just replacing shocks? If so, what is a favorite on a limited budget (used OK, maybe $200?) BTW, daily driver, never on track.
Kleeborp the Moderator™
Lowering the car that much has left you with basically no options with your budget...you've eliminated too much of your suspension travel, so the shock just won't have enough time to work its magic before you go hitting the bump stops.
If that is your budget, it might be wiser to get a better set of springs.
Rears only
What would happen if I just replaced the rear shocks? That is where I feel the harshness of the bumps. What shock might give the best bang for the buck in the rear? Is it as big a job to swap them out as the springs were?
LS1TECH Sponsor
Rear shocks could help (won't hurt), It's literally 4 nuts to get them off, about the same work you did with the rear springs.
But MeentSS02 is correct in that a shock can't take over a spring's job. Too low a ride height or not enough spring to keep you from just slamming onto the stops isn't something a shock can stop. It can help because they can slow the speed you hit at, which is part of their job.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
