How much torque I need on a spohn rear swaybar?
I have a spohn swaybar w/ the installation kit and I need to how much torque is required for the nuts. I seem to only got the first page of instructions. There only 3 steps? I think I'm missing some pages. Oh and is there a special way I should be installing the swaybar? All I did was attached everything and bolted it up. Thanks
the sway bar is pretty much just a remove and replace. ls1howto.com shows an install of a rear sway bar....as for the torque settings here ya go
http://www.ls2.com/boggs/torques/rea...ifications.htm
LS1TECH Sponsor
For end links you want to tighten them until you see the bushings start to compress, then stop. Do this at ride height of course.
Steve
