best set up for drag racing
im wondering what the best set up for drag racing would be?
what would be needed to get the most postential out of the car?
thanks for any help.
there is a lot of opinions out there on what is good, here is a thread(one of the very very very many that came up with a search)...hope that helps bro
https://ls1tech.com/forums/showthrea...uspension+drag
that helps.
i knew what kind of parts i was going to need i was looking for brands and different opinions. i have already upgraded some of my suspension pieces and the front sway bar mod.
ive had exelent luck with qa1 12 way adjustable shocks with the drag coils in the front, i have stock z28 springs as well with qa1 in the rear with BMR lower control arms. i recently put in a spawn k-member with lower and upper control arms. havent ran the car yet. with the stock junk k-member and that set up on a procharger it went a 1.49 60foot on the back tires. good luck man!
LS1Tech Premium Sponsor
you need shocks... then a good torque arm setup, lca's, relocators, and a panhard if you have the car lowered.
you have a dual exhaust setup, so you're kinda limited on t/a's. i so happen to have a crossmember available for the duals with a loop incorporated, adjustable torque arm link, and a bitchin' chromemoly torque arm. Strange and AFCO shocks also are on sale now.
pm me or call the shop for complete quote. everything listed in the vendors sale section.
