adjustable lca's
Old 12-25-2007, 08:06 AM
XX11SECZXX's Avatar
Default adjustable lca's
going to buy double adjustable lower control arms. want to order them today. pretty sure im gonna buy the chromemoly rod end ones from umi are these ok for street driving? am i going wrong with umi? should i buy spohn, bmr or some off brand type? i figure they are pretty much the same. anyone cheaper then the other?
Old 12-25-2007, 08:39 AM
JScamaro's Avatar
Don't hesitate to go with UMI they are great. I have their lca's, torque arm, subframe connectors, and panhard rod waiting to be installed.
Old 12-25-2007, 08:56 AM
bryan04h's Avatar
x2 with umi...umi makes excellent products..you can also check out bmr, that is what i am using
Old 12-25-2007, 09:06 AM
XX11SECZXX's Avatar
should i buy the single adjustable or dual? this is not an all out drag car. basically i drive it to the track and to shows, and once a week for a cruise. will the single adjustable work for me or do i need dual?
Old 12-25-2007, 09:38 AM
2_wacko's Avatar
I have the UMI single adj with rod ends. If its a street car I would get the poly ends. The rod ends make some extra noise.
Old 12-25-2007, 09:40 AM
XX11SECZXX's Avatar
am i giving up anything by doing one poly end of is it not noticeable. umi has a 10% off sale so im going to order today.
Old 12-25-2007, 10:12 AM
NHRArox's Avatar
im also interested....suscribed
transamws6_97's Avatar
if you dont mind your suspension making noise go ahead and get the double adj. The best bet would be single adjustable for your purposes. Double adjustable is overkill and rod/poly ends will be more friendly than rod/rod ends
Old 12-25-2007, 11:43 AM
XX11SECZXX's Avatar
i drive with a spool in the back and i think the rod ends would wear out fast.
Old 12-25-2007, 09:01 PM
XX11SECZXX's Avatar
i placed an order on the umi package deal with the single adjustable lcas and panhard bar, and a set of weld in relocation brackets for the moser rear. hopefully my traction problems will be gone. now that i have placed the order i have people emailing me to buy their parts. sorry about 3 hours to late.
Quick Reply: adjustable lca's
