Vibration~
Vibration~
Okay so after installing the Konis and factory springs on the car, the very next morning I went to get my alignment. Well after the alignment I got on the interstate and could feel a slight shake in the steering wheel. So, I got the wheels off of the car and went down to the tire shop and had them rebalanced. They were "off" by 1.5 ounce on two tires and about an ounce on the other two. Any reason why a set of tires with about 2k on them would be doing that? Okay not really the most important part.......
So I watch them balance them and one of them has a slight shake to it on the machine. The guy points it out as well but it balances out on the machine. So get them back on the car and they DO feel alot better but at about 75-80 I feel a pretty good shake and then about 90-95 its enough to make me not want to push it much more. Any ideas? Tire pressure is about 32psi all around. Can't figure it out unless there is an egg on the tire or a bent rim, but I don't see it. How can I check?
