Identifying 3 Vs. 4 channel ABS
Old 12-26-2007, 04:08 AM
robertbartsch's Avatar
Default Identifying 3 Vs. 4 channel ABS
I have a 1999 SS. Does this have a 3 or 4 channel ABS?
Old 12-26-2007, 08:04 AM
LS1Tech Premium Sponsor
BMR Suspension's Avatar
Based on the year I would say 3-channel but a good indicator is if you have traction control. If you have traction control you have 4-channel ABS. Another way to tell is just by visual looking for the sensor on the centersection it is pretty easy to spot. If you have the sensor it's 3-channel if not it's 4-channel. If you have any other questions you can give me a call here at the office and I will see if I can help.
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old 12-26-2007, 09:05 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Whether or not you have traction control is the easiest way to tell...traction control = 4 channel...otherwise, it is a 3 channel.
There are a whole host of other ways to tell, but I'm pretty sure you'll already have your answer.
Old 12-26-2007, 11:15 AM
ssvert99's Avatar
traction control button on the dash=4 channel. wire harness connectors at the rearend brake backing plates = 4channel. sensor/wire harness connector on top of gear area on housing=3channel.
just a few other ways to tell....
Quick Reply: Identifying 3 Vs. 4 channel ABS
