kyb agx's and a few ?'s
i was looking at some of these threw my work
KYB-743019
KYB 741034
my car has 100k on it and i bought replacement monroe sensa track struts but never installed them so i was gonna return these and get the kyb's
i would like to get a better set of springs for the car to maybe up the handleing and lower it 1.5in maybe but not be real bumpy/bouncy when i drive
i like the smooth stock ride, but dont want stock springs
i was told i'll need a chamber kit if i get lowering springs, what else do i need to do or should i do?
anyone have any input?
KYB-743019
KYB 741034
do not get kyb shocks if you plan on lowering your car...they arn't made for that...if you are going for a good set of springs/shocks, check out stranoparts.com...i lowered mine with eibach and have bilstein shocks..it has a nice look and performs well for me...for my drop i don't really need a camber kit..but i could use one i guess...
What's a chamber kit? Bouncy bouncy is what you feel if the shocks can't control the springs. I have not heard too many good reviews about KYBs on aftermarket springs. A few but a lot of garbage reviews and some people who didn't care about the harsher ride. My camaro is more comfortable on strano/koni combination than my STI is stock though fwiw. Konis are pretty good shocks for aftermarket springs. I'd never put a Monroe shock on my car and I'd think twice before putting KYB's on the car to dampen stock springs, never aftermarket though
F-Bodies have solid rear axles and adjustable camber from the factory so you don't have to worry about that.
KYB-743019
KYB 741034
KYB-743019
KYB 741034
direct comparison here:
https://ls1tech.com/forums/showthrea...light=koni+kyb
Another thread:
https://ls1tech.com/forums/suspension-brakes/83761-update-kyb-agx-shocks.html
i am only considering these because of where i work at these are the best we can get sadly, and with my bouns and over accumulation of comission i can get these for nothing.
anything is better then my 100k stock shocks right?
Ever thought of a reason you get them for about nothing lol.
Better, maybe yes, but not for any sort of lowering springs. The min for lowering springs is revlaves and since the hds are on backorder there really hard to get.
So the cheapest is the konis 3/4 for you.
^^^i like them, when i first started looking into lowering my car i read a lot about the bilstein shocks and how ppl liked them...put them on and they felt great...i haven't had a problem when them at all, i do race my car and i could do better with koni's but not everyone has the money to put down on them ya know.....so i went with what i thought would be good
LS1TECH Sponsor
The god's honest truth is that I'd have to recommend AGX's over the HD's for lowered cars. The AGX's simply have more oomph to control the springs than the HD's do. The "old" HD's weren't enough for a good handling car, the new ones are better in one way (more reboud in front=better, but less compression in front + more in the rear and less rear rebound=bad). So, even if HD's were around and they aren't, they are not a workable solution IMHO.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
