TA - tunnel or X-mount for HANDLING?
OK, so I still have some wheel hop after adj. PHB, adj, LCA, shocks, Samie sways, etc.
I have some older LT headers - FLPs, Y-Pipe, etc.
Which torque arm is best for handling (1) tunnel mounted "short" TA, or (2) a transmission mounted (or cross over transmission) TA?
If the transmission cross-over mounted TA is best, will it interfere with the LT headers and Y-pipe?
LS1TECH Sponsor
Short TA's move the instant center rearward which is not what you want for balance upon accelerating from corners. And they transmit more noise because they are bolted to sheetmetal floorpans.
Stay full length, you have no fitment issues. If you just gotta have the TA off the tranny, we'll run a TA relocation bracket that still uses a full length TA and doesn't interfere with exhausts as it's a replacement transmission crossmember (and you have one of those already in place, we just change it to this so the TA can mount to it and not the transmission itself).
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
TA's (non adjust, adjustable):
http://www.stranoparts.com/partdetai...D=18&ModelID=7
Bracket (stick or auto, for LS1--LT1's have different units):
__________________
