Best trans mount?
Old 01-07-2008, 11:26 AM
WS SIKZ's Avatar
Default Best trans mount?
weich trans mount is the stiffest besides solid if they even make one? i def want poly but weich on is good? and do i have to change the motor mounts to or no i can leave the stock ones, also who has the cheapest and best trans mount?
Old 01-07-2008, 03:44 PM
robertbartsch's Avatar
Any aftermarket poly transmission mount would be good choice Vs. the stock tranny mount for curing certain issues. Why are you considering this?
My LT headers used to bang often and I switch the factory tranny mount to a poly unit and it fixed the issue in about 15 minutes of effort. Motor mount changes are more diffucult and time consuming.
Old 01-30-2008, 10:43 PM
PrototypE's Avatar
yeah, i was wondering this as well, is it really necessary to replace the motor mounts with poly as well when upgrading to a poly transmission mount?
Old 01-30-2008, 10:46 PM
Manic Mechanic's Avatar
No it's not necessary, you could run any combination of poly and rubber. There's strong and stronger, stiff and stiffer but anything's better than broke. Poly can increase vibrations over good rubber ones, that's a fact.
Vernon
Old 01-31-2008, 11:50 AM
RedLS's Avatar
If you do decide to switch to a poly trans mount, go ahead and get the poly motor mounts. If you run a stiff trans mount and stock mushy motor mounts it puts stress on your bellhousing and can cause it to crack.
Old 01-31-2008, 02:05 PM
shannon french's Avatar
man i didn't know this an di got just a poly mount fo rx-mas. glad i hadn't instale dit yet
Old 02-03-2008, 11:57 AM
RedRyder518's Avatar
I put on an Energy Suspension poly mount and it sure does transfer more vibrations. Just be ready for it as some don't mind it, some hate it. I also have the ES poly motor mounts.
Old 02-03-2008, 04:36 PM
dpw41285's Avatar
just run the stock rear mount. if you upgrade to solid or poly motor mounts youll prolly be annoyed if you have a poly trans mount. i will be running a new oem trans mount and solid motors
Old 02-03-2008, 09:58 PM
3.4camaro's Avatar
I run solids and a stock tranny mount.
No engine movement + no interior vibes. I love the setup.
Quick Reply: Best trans mount?
